01 s430 brakes
Old Jan 5, 2008 | 07:47 PM
wpimetnel's Avatar
Default 01 s430 brakes
That by far was one of thesimplest brake jobs I have ever done! (and I have not done many)
1. take wheel off
2. knock pins out...remember how the clip sits under the pins
3. pull old pads out...you may have to compress the piston with a screw driver
4. put new pads in
5. put pin and clip back on
6. new sensor
7. put wheel back on..this was the hardest part!!!!!!
rears only have one pin...
I can't believe how fast that was!!!!
Old Jan 6, 2008 | 01:07 PM
ARMENDS500's Avatar
Default RE: 01 s430 brakes
thanks for posting that, i have to do mine soon, altough i may have to replace rotors too.
Old Jan 6, 2008 | 04:03 PM
waffler's Avatar
merc brakes real simple to change did mine a while ago and thought it would be complicated but was real simple
Old Jan 6, 2008 | 10:36 PM
snanceki's Avatar
Standard job. Similar on most cars.
Maybe you compare with front wheel driver single sided calipers which require the caliper to be removed.
Note: Don't forget to correctly torque the wheel nuts (lugs). Rotors like to be seated with even clamping load to avoid warping etc.
Stuart.
Old Jan 8, 2008 | 09:29 AM
wpimetnel's Avatar
do you have the proper torque settings?
ph1958
Jul 12, 2009 12:43 PM
wpimetnel
Dec 18, 2007 04:36 AM
placek
Apr 9, 2007 11:44 PM
coolvt
Oct 20, 2006 01:37 PM
coolvt
Oct 4, 2006 10:35 AM
