Won't Shift Out of Park
Old Oct 4, 2006 | 01:18 PM
lhemmer's Avatar
Default Won't Shift Out of Park
I've got an ML320 which won't shift out of park unless you press the reset (using the filler from a ball-point pin).
While this method does work, it is tiresome to stick a pen in a $30K car every time you want to shift out of park.
My BAS/ESP light came on at the same time and I am certain they are related.
I don't want to just take it to the dealer -- suspect they will 'find' an expensive fix. Car is running fine, don't need heroics, just want to shift normally. [:-]
LHemmer11
Old Oct 6, 2006 | 12:56 PM
YuCrew's Avatar
Default RE: Won't Shift Out of Park
Has your brake light switch failed (brake lights work? cruise control work?). If yes, the good news is that this is a simple fix (and a common failure). How many miles on your ML?
concord
Jun 16, 2020 02:09 AM
mercedesman232
Feb 22, 2014 05:51 PM
so clean1
Sep 2, 2008 07:27 AM
Ezbiker
Feb 23, 2008 10:35 AM
bpham
May 25, 2007 08:00 AM
