Retrofit SatNav to 2002 ML320
Old Sep 26, 2005 | 08:49 AM
speedcheese's Avatar
Default Retrofit SatNav to 2002 ML320
I'd like to retrofit SatNav to a 2002 ML320. I've taken out the radio that I currently have an it appears that there are a lot of additional (currently unused) cables in the wiring loom behind the unit which I assume are for SatNav. One looks like an aerial plug and another looks like an RJ45 socket. There are many others. Are these used for SatNav ? I'm assuming that when the car was built, it had a "standard" wiring loom included which allows for SatNav to be retrofitted without a significant amount of additional wiring.
My other question is what head unit(s) would be suitable for this car ? I've seen several different versions and want to know which would work. I'm assuming the answer is not just "any double-din" unit - it must be more specific. If anyone has any part codes for units which they know work on this model of car, I'd appreciate any posts.
Thanks in advance
as400
Aug 31, 2009 03:18 PM
digitalis49
Mar 17, 2009 07:18 AM
briangreen41
Jan 3, 2009 05:27 PM
speedcheese
Sep 10, 2007 08:39 PM
stomsf
Apr 11, 2004 01:22 PM
