ML430 Gauge cluster
I did it twice because of burned out backlight bulb but the second time I have replaced them all just to make them last longer.
Pull off plastic covers on the side of the steering wheel columb.
Move the steering wheel to its lowest position.
Unscrew or loosen up two phillips plastic screws of the cluster frame bezel cover and pull the top toward you while inserting small screwdriver into two locking tabs at the bottom (one at a time) to release it and pull up (out).
Remove two screws (8mm socket head one on each side of the cluster) and pull it out enough to reliese cable connector lock on the back.
Very easy task.
Good luck,
Bernard
Very easy task.
Good luck,
Bernard
slyc230
04-19-2024 10:10 AM
ddtbreakfast
04-21-2008 11:34 PM
bfigueroa
08-16-2007 05:20 PM
