ML320 Remote start key
Old Jul 25, 2011 | 04:00 AM
PuppyRaj's Avatar
Default ML320 Remote start key
I am very new to this blog and very new to ML320. I recently bought a used ML320 model 2002 from a relative. I changed the batteries for remote key entry/start. The car doesn't seem respond any more for remote. I followed the instructions (insert key, two clicks, press door close button, ten times turn on/off window lock, etc). Still remote entry is not working.
Appreciate any assistance.
Thanks.
Old Jul 25, 2011 | 04:06 PM
coolishlobster's Avatar
turn ignition switch to position II
turn ignition switch to position O and remove key
with in 1 min
press and hold the lock button on the remote
press unlock button n the remote 5 times
remote control should now operate
if not repeat all again.
Old Jul 26, 2011 | 05:44 AM
PuppyRaj's Avatar
Default ML320 Remote Start Key
Hi Coolishlobster,
Thanks for the info.
Are you referring to the Lock/Unlock key on the remote or the ones in ML320?
Old Jul 26, 2011 | 02:34 PM
sorry on the remote,i have updated the procedure
Old Nov 20, 2011 | 08:27 PM
rwflier's Avatar
Thank you, it worked on my ML55!
Old Mar 22, 2012 | 05:16 PM
PuppyRaj's Avatar
Default Puppy Raj
My 2002 ML320 battery is down and nt taking any charge. I tried removing the battery, but unable to remove it. I took the cables off, took the nut at the bottom of the battery. Moved the plastic holder away. Yet the battery doesn't budge. Can someone list me proper ways to remove battery?
Old Mar 23, 2012 | 04:05 PM
your doing it right so far but you will have to tilt up the positive terminal side and bring it out at a angle ......remove the rubber seal around top (two sides to battery) and remove the bolt you also have to lift out end plate battery surround and pin this back while pulling out battery (another helper at this point is best)....make sure you disconnect leads first because when you pull up this surround some of it is metal and will act as earth still and could touch positive lead if battery still connected,so disconnect leads and pin them back out of way to be safe!
oh yes the battery is heavy so them flip up handles come in handy when having to tilt battery.
hope this helps.
todesto
Aug 14, 2021 06:42 AM
Daniel L.
Nov 26, 2012 12:05 AM
racerev
Mar 26, 2011 04:50 PM
Jack21
May 4, 2010 10:23 PM
JOIFUL
Apr 21, 2008 09:09 PM
