ML320 humming when you press the gas pedal
Old Nov 22, 2010 | 08:55 AM
benzlover49424's Avatar
Default ML320 humming when you press the gas pedal
I have an ML320 1998. A couple of weeks ago i started hearing a humming sound when I would press the gas pedal.
Once you release the gas pedal it stops even if the car is still coasting. When I put it in park and pressed the
gas pedal, it still makes the humming noise. Is this a transmission problem? Please help!
Old Dec 1, 2010 | 09:11 AM
mbenz80's Avatar
It sounds like bad bearing somewhere ( in alternator, serpentine belt tensioner or in the transmission). Also could be loose cat converter blockage or vibration resonance.
You forgot to state how many miles is on your ML320.
Bernard
Paradocs
Jun 14, 2010 07:56 AM
lister1000a
Feb 24, 2007 08:17 AM
mgw_300e
Jul 2, 2006 03:06 PM
shogomad
Feb 25, 2006 11:58 PM
Max In Montreal
Sep 2, 2005 06:11 PM
