ML320 DS Outside Front Door Handle Broke...
The the outside Drivers Side handle won't open the door on my 98 ML320. Inside works fine. The outside handle spring has tension and looks ok, but it has no effect on opening the latch.
I took the trim panel off and tried to look up into the area where the handle is, but can't see too much. But from what I can see, I don't see any obvious problem. I don't know if I need to replace the outside handle, or door locking latch, or if something just jumped out of whack on the inside. If I do need to replace the handle or latch, it is not obvious how to do this. Suggestions would be appreciated. I am fairly good at DIY.
Any help in fixing this problem would be much appreciated.
Deltmooro
Mar 23, 2021 08:39 AM
fitale
Oct 10, 2013 07:25 PM
landsteam
Nov 5, 2011 09:26 AM
