Ml 320 2006
fuel filter contains the fuel pressure regulator which will cause an extended crank after sitting for about 15 minutes or longer. cold or hot makes no differnce when this goes bad. it will just happen always if you let it sit for a bit. you need to check your fuel pressure at the fuel rail. should be about 60 psi and not drop too much below that no matter how long the car sits.
vvcd
Feb 12, 2008 08:24 AM
