Front and Real Brakes - ML-500
Old May 26, 2006 | 01:26 AM
h0kiku's Avatar
Default Front and Real Brakes - ML-500
I am trying to replace the brakes of my 2002 ML-500. Currently, I am working on the real brakes. I replaced the Real rotor with no problem, but I could not pull the old brake pads out. Can someone please help me. Thanks a lot..!!!
Old May 27, 2006 | 09:29 AM
gsfent's Avatar
Default RE: Front and Real Brakes - ML-500
ORIGINAL: h0kiku
You need to tap out the pins. Once started, they can be pulled out by needlenose pliers. After you take out the first pin, the retaining clip should slide out. Note orientation of the clip. Once the pins and clips are out, the pads will slide right out. Installation is reverse of removal, only semi difficult part is tapping the pins back in from the inside. Have a good small hammer available. You will also need to compress the pistons before the caliper will fit over the rotor with the fresh pads. And use plenty of anti squeal on the pad backing plates.
Regards,
Jerry
Old Apr 16, 2011 | 03:42 PM
jose castro's Avatar
Default front rotors 2002 ml5oo
hi there, can someone tell me how to replace the front rotors on a 02 ml500.. i got the pads off so far but having problems pulling the old rotor out.. thanks
Laura75
Oct 5, 2010 12:38 AM
BullOnWallSt
Sep 15, 2008 06:32 PM
allyreese
Nov 23, 2007 02:00 PM
KenjiTsou
Jul 11, 2003 02:51 AM
