Fan not starting in Ml320 98
Old Jan 13, 2007 | 03:07 PM
yusufyila's Avatar
Default Fan not starting in Ml320 98
I noticed recently that both fans were not starting even after a long drive. Funny enough, the car does not over heat (temperature hovers at 80 degrees). I sent it to the workshop and they tell me that it a switch that starts it is bad. the switch is replaced and fan does not still start. Now the car has stopped and I'm told the fuel pump is bad.
When is the fan supposed to start ? even when i turn on the Air condition the fan does not start !
Old Jan 13, 2007 | 08:05 PM
MBZTech's Avatar
Default RE: Fan not starting in Ml320 98
This is a very common problem. Just about every ML that pulls into the shop has this problem and the customer doesnt even know about it. You have a blown fuse!!! There is a wiring harness upgrade and bigger fuse for your fan problem..
For your no start problem.... Check your fuel pressure
rschleicher
Mar 10, 2014 08:22 PM
seadog
Feb 16, 2011 07:17 PM
red5jedi
Apr 23, 2010 03:26 PM
vsalico
Oct 6, 2009 07:38 AM
haidarsaid
Jan 22, 2005 11:51 PM
