99 ml320 dash cluster clocks
Hi all has anyone had or having the same problem.....my fuel gauge is very erratic as it reads a different level between start ups....also the temp gauge does not rest or start off smooth but it(flickers for a bit before trying to give reading ........basically what happens is when i switch on the ignition or start up there is a delay in all readings for at least 2/5 seconds then all dials work.....could it be faulty dash clocks.......also another thing i have noticed is when i put the ignition on position 2 before start all the lights are on but the check engine(the one about halfway along the bottom lights in cluster).....is this normal or should it come on and go out(i have changed the bulb to one i know works ) ....or is it just designed to come on if there is a fault.....apart from the false readings on the dash the car drives spot on so no reason for a management check engine light to be on!......any help advise much appreciated,thanks in advance.
jerzstyle00
04-22-2011 10:05 PM
rich121
10-07-2005 09:40 PM
