98 ML 320 water pump help
I have recently purchased a water pump to replace my failed one, and I need help. This is about my hundredth water pump job but mostly all Chevys of varying types and years.
1. What are ALL these bolts?
2. Can somebody post a belt diagram?
3. The first bolts to remove are hex head (?) and the fan is too close too
get an allen wrench in there! Should I use a hex bit from a nut driver set and a wrench (6mm?) to get in there?
4. My part came with the standard gasket with the holes in it but it also came with a rubber gasket or seal with tabs on it that can only go inside somewhere...but where?
5. After the first 4 bolts come off and I get the belt off I see few troubles but what other components must be removed, since I see some bolt sleeves in the holes on the water pump?
ANY HELP AND ESPECIALLY PICTURES WOULD BE APPRECIATED GREATLY!
kanio
09-15-2006 04:25 PM
