2001 ML 320 rear seatbelt replacement
Old May 30, 2007 | 06:09 PM
8092400e's Avatar
Default 2001 ML 320 rear seatbelt replacement
Had a fuel pump replacement done today (love that extended warranty) and inquired about fixing the passenger rear seatbelt (no longer retracting on the shoulder belt) He told me it was $500.00!
I just ordered the assembly from the benz bin for $105.00. Does anyone have any hints on replacing this? Any things to not do or screws in odd places or weird trim clips, other things to remove?
thanks!
John
2001 ML 320
1992 400E
Old May 30, 2007 | 09:34 PM
MasterBenzTech's Avatar
Default RE: 2001 ML 320 rear seatbelt replacement
not sure about this but if could help. on the right side panel in the car where the seat goes behind the panel. if there is a "SRS" plastic cover, it should pry off there will be a screw behind it. wehre the panel meets the headliner you can pry the off by hand. it is held on by two clips. you can also partily remove the weather from the door jam to take a look behind the panel. if you need more help shoot me a message and i can look it up.
Old May 31, 2007 | 10:36 AM
8092400e's Avatar
Thanks!
I am going to tackle it this weekend. I bought the service manual for my 92, its helpful. Would you recommend shelling out the $80.00 for the 2001 ML manual?
Old May 31, 2007 | 12:00 PM
If you plan on working on the car, instead of going to the dealer.
ian3375
Feb 9, 2014 09:09 AM
rmarasco
Apr 14, 2013 07:28 PM
doctor28
Apr 7, 2004 08:00 AM
jon124
Mar 16, 2004 12:03 PM
rotang
Oct 23, 2003 02:26 AM
