Mercedes-AMG G63 Carbon-Ceramic by TRONIK: No Compromise on Price or Performance
Hey everyone!
Many owners of high-performance vehicles dream of upgrading to a carbon-ceramic braking system. And for good reason carbon-ceramics offer exceptional heat resistance, consistent performance under stress, reduced weight, and a distinctly premium appearance. However, the price tag on OEM systems can easily match a significant portion of a new luxury cars value.
At TRONIK, we set out to create a smarter alternative: a setup that maintains reliability, longevity, and performance without the inflated cost. We successfully implemented it on the Mercedes-AMG G63.
🔧 The Kit: Balanced Engineering, Thoughtful Execution
At the heart of the project are high-performance rotors manufactured in Asia, long proven in demanding applications.
Front Axle:
Carbon-ceramic rotors 420Χ40 mm
Aluminum rotor hats
Ceramic brake pads
Custom front adapters (L/R) engineered by TRONIK
Mounting hardware
Rear Axle:
Carbon-ceramic rotors 410Χ32 mm
Aluminum rotor hats
Ceramic brake pads
Custom caliper carriers engineered by TRONIK
Mounting hardware
⚙️ Titanium bobbins are used to connect the carbon-ceramic rings with the aluminum hats, ensuring strength and thermal stability.
📉 Unsprung weight is reduced thanks to lightweight aluminum parts which improves ride and handling.
🟩 A key advantage of this system: the factory AMG calipers are retained.
That means lower overall cost and full compatibility with OEM hydraulics and electronics.
🛠 Installation: Precision Work, No Corners Cut
The full installation was carried out at the TRONIK workshop:
OEM steel braking system removed
Hubs and mounting surfaces cleaned and prepped
Carbon-ceramic rotors installed to factory torque specifications
OEM AMG calipers retained
New ceramic pads installed
Brake system flushed and refilled with fresh high-temp fluid
Everything was done in-house, with strict attention to detail and tolerances.
🚀 The Result: True Carbon-Ceramic Feel Without the OEM Price
Sharp and confident braking, even at highway speeds
Zero brake fade, even after repeated hard stops
Reduced unsprung mass improves control and comfort
Visually stunning the rotors look right at home on a G-Wagon
All this, without paying the full OEM price for a carbon setup.
🔄 Now Available for GLE 63 and GLS 63
This solution isnt just for the G63 the same platform can be adapted to other AMG models, including:
Mercedes-AMG GLE 63 / GLE 63 S
Mercedes-AMG GLS 63
💬 Conclusion
Looking for carbon-ceramic performance without brand markup? TRONIK delivers with engineered solutions, expert installation, and results that rival OEM systems.
