Where can I find a fuel injector?
I have a 2002 E320 and I believe I have a faulty fuel injector that is leaking on my spark plugs in cylinder 1 which is causing a misfire.I usually have no problem finding parts but I cantseem find fuel injectors anywhere. How many injectors are in my car and where can I find them at online or in the Dallas,TX area? Any info will be greatly appreciated.
Please STOP & THINK for a minute. Changing parts unnecessarily is a very exopensive process especially when you discover that the new parts don't solve the problem!
There are 6 injectors on your motor which are accessed once you have removed the large plastic cover/air filter on top of the engine. they are attached to the fuel rail which must be removed first in order to remove an injector. each injector is connected to the engine wiring harness by a connector with two wires.
IF (I repeat) IF the No.1 injector is leaking then changing its position to Cyl No.2 or where ever will move the problem. Have you done this as I suggested. I suspect that once you have you will discover the problem DOES NOT move therefore I will have saved you a fortune.
Have you carried out a compression test yet + all the other things that i suggested.
If so what were your findings?
Stuart.
Stuart.
We keep telling you to do the same things,and for all the money you have spent without solving the problem you could have had a good indie shop fix it,and I hardly ever suggest that.You are not finding out the problem you are just throwing parts at it to find the solution.
if it happens to be the injector www.germanstar.net Or you are in a big city,they have injector service shops that will clean refurbish an injector .
cobbcfi
Jul 23, 2010 07:17 PM
rt30000
Dec 16, 2003 09:46 PM
