wet windows
What you have my friend is a water leak from the outside. I would suggest you find a engine smoker used for finding vacuum leaks and turn it on and put a positive air pressure from the window into the interior. If there is a plug or corrosion letting water in, you will see smoke coming out of the vehicle.
Also, inspect every square inch of your vehicle inside a garage after driving though a horrid rain storm. Wetness will indicate where the water is leaking in.
khwaja
Mar 18, 2009 05:34 PM
