W124 '87 300E Blower motor motor intermittent then dead!
Old Jan 1, 2007 | 07:05 PM
xb70valkarye's Avatar
Default W124 '87 300E Blower motor motor intermittent then dead!
Hello. I have a 87 300E with the puch button climate control. A little while ago the blower motor would sometimes not start and sometimes would. Then one day it just stopped working all together. Reading the forums here I see that it may be the "porcupine" regulator. Before I spend the money on it is there anything else I could check? I have also noticed that when it did work, no air would come out of the bottom foot vents. Could it be the main control unit? Appreciate any help.
Old Jan 2, 2007 | 07:29 PM
leon s.'s Avatar
Default RE: W124 '87 300E Blower motor motor intermittent then dead!
The fan of the climate control of my '88 300TE stops and goes on it's own. My guess is once the set temperature was reached the fan stops and back again later.... this is only my guess, so correct me if I'm wrong.
Old Jan 3, 2007 | 11:56 AM
jackd's Avatar
Have you checked both fuses?
yes, there are 2 fuses for the blower motor.
Old Jan 3, 2007 | 05:18 PM
I have checked 1. Is the socond one also on the fuse box? I will look for it.
I know the fan does not go off after the desired temp is reached. For me the fan does not even come on.
Old Jan 3, 2007 | 06:06 PM
jackd's Avatar
The second fuse is located on top of the left side (driver side)fender inside the hood, besides the shock mount.
There is a little black plastic box (about 2in by 1in) When opened, you'll see a one inch long metal strip. Corrosion sometimes sets-in. Remove the fuse (2 screws), clean everything and try your blower.
Old Jan 7, 2007 | 10:58 AM
RCJones's Avatar
I just had to change my motor. I was suffering the same problem. Thought it might be the blower regulator, but when I got the motor out it was shot. Had to drop in a new motor. I did it myself
Old Jan 8, 2007 | 12:50 AM
Well the motor has started working again on its own. I am afraid to use the Auto button in fear that it might not start again. Could the regulator just need a thorough cleaning? Do we still think it is the regulator? I found the second fuse and it was nice and clean so I am still not sure.
Old Jan 8, 2007 | 03:12 AM
leon s.'s Avatar
OK...xb70valkarye...
when the fan stops and I want to activate it (because I don't want to wait), I hit the Auto button for few seconds and then it will cancel the cycle.... then I hit any other button I wnat with the fan blowing...
Old Jul 29, 2011 | 08:15 AM
  #9
MED's Avatar
MED
Thank You! My fuse was broken which was causing the blower not to work.
Old Oct 8, 2012 | 11:51 PM
  #10
Khalid Eledlebi's Avatar
hey i have a 1995 e320 with the same issue all fuses are good i changed the regulator and the blower motor spun a little i had b+ at the middle terminal located behind the brake booster now i have nothing i am going insane looking for the problem could it be from the harness inside the car please i need info car is for an annoying customer a.k.a my brother
bluesky 2008
Apr 28, 2008 02:00 PM
rosen128
Aug 25, 2007 02:39 PM
mfoy
Dec 20, 2006 11:11 PM
Ellen Ward
Dec 13, 2006 06:02 PM
C280 wizard
Aug 24, 2005 10:41 PM
