very poor raido reception
Old Jun 8, 2012 | 06:22 PM
CJATE's Avatar
Default very poor raido reception
I've got a 96 with factory head. It had no antenna, so I replaced it. now the antenna does not go up/down, but I can slide it in and out manually. I don't care for the auto up and down function, just want it to receive radio reception.
when I get in and look at the mechanism, I don't really see how the antenna is hooked to radio. the motor has a three plug, i assume that is power up / power down and ground. I don't see a signal wire headed to the front. I can't see anything hanging not plugged in and don't see a plug that is missing it's connection. I do see a 12 or 15pin laying on the floor in the area but assume it goes to CDchanger or other.
Please advise with pictures, if you can.
I drive 45 min each day, and get sick of the lack of reception (AM specifically)
I did verify it's plugged into back of radio. I don't want to buy a new head, if I don't have too.
Old Jun 9, 2012 | 12:34 AM
PelicanParts.com's Avatar
Default Answer
There is a coaxial cable attached to the antenna assembly, it may be damaged or not connected.
The antenna case ground must also be intact to reduce static, and for motor function.
Roy@PelicanParts.com
Last edited by PelicanParts.com; Jun 12, 2012 at 11:02 PM. Reason: restoring my e-mail address
Old Jun 9, 2012 | 08:36 AM
CJATE's Avatar
Yep, both coax and ground are missing. Anyone know where to start looking?
I googled a bit about this, any way to know if the antina is in the fender or built into the back window? I can't tell on my make.
Old Jun 9, 2012 | 09:45 AM
Default Answer
You should climb in there with a strong light and mirror to look around.
It is in the driver rear quarter panel area.
I hope the previous owner did not cut it off, or remove it.
GzuS
Sep 19, 2009 12:37 PM
Frankieboy057
Oct 18, 2008 07:48 AM
christopherjon76
Jan 5, 2008 08:39 PM
Victormyboy57
May 20, 2007 10:53 AM
SLK320Chic
Sep 29, 2005 04:44 AM
