steering ignition column 190e
Old Mar 23, 2004 | 02:07 AM
john5's Avatar
Default steering ignition column 190e
Please help with a major issue i'm having.</P>
I need help with removing the ignition steering column lock. All nuts and bolts are removed, but it still doesn't want to come out.</P>
The key is stuck in the ignition and won't turn or release.</P>
Old Mar 23, 2004 | 04:47 PM
stephen's Avatar
Usually any tumbler has a release pin to be pushed in either on the top, bottom or held by a snap ring Once release, the tumbler should need to be rotated to a certain position before it can be pulled out. </P>
No luck still,,,,,check your local mercedes repair guy, they will tell you or the dealer can give you a picture of that assembly.</P>
Ususally if you need tumbler or new keys, they take you VIN to assure you get the correct key and that the vehicle is not stolen.......other than that...no worries</P>
Old Aug 28, 2010 | 03:16 PM
scottlowry09's Avatar
i have a 190e and am trying to remove the ignition.the key will come out but im trying to get the collar off
tharding
Mar 30, 2012 09:13 AM
john5
Mar 23, 2004 02:01 AM
protoman
Dec 6, 2003 01:50 PM
bgods
Nov 24, 2003 12:14 AM
Maxiemack
Sep 24, 2003 12:42 PM
