SRS light can I scan it?
What year model again?No you can't scan it.A good indie shop mb with the proper star machine can,so call around.They will be much less than the dealer.Most of the E320 srs light issues are passenger seat occupancy seat sensor failures.Inspect the wires and diy r/r is on benzworld.org w210 diy section.You remove the seat,part is about 150 bucks,you replace it,etc.
ohlord
ohlord
You need a shop with the correct type scanner.
Doesn't have to be MB SDS Star.
OBDII compliant scanners only read the eng/trans module.
Seat switch is high on the list of possible causes BUT ensure you follow normal safety procedures with SRS.
rcltrh
11-24-2005 09:44 PM
