Seat stuck
Old Sep 2, 2011 | 10:18 AM
engin1234's Avatar
Default Seat stuck
Drivers seat will not move front to back. Till, headrest and up and down works and fuse is OK, 1999 CLK 320
Old Sep 2, 2011 | 03:35 PM
JohnnyRaggs's Avatar
look under the seat and make sure that the seat control module is still plugged in, if it is, then you may need a new module.
Old Sep 2, 2011 | 10:06 PM
chassis221's Avatar
check all fuses. mainly in the trunk by the soare tire....small fuse box with fuses for seats and also some in the front fuse box. usually the fuses in the trunk blow
Old Dec 5, 2011 | 02:26 PM
Jewjenk's Avatar
Same thing on my 2003 C240, seat will not move back and forth can hear some type of relay clicking from under the seat when I hit the switch. All other functions work. checked all the wiring, pulled out and reset the connections and checked fuses..........................Could the motor be gone?
starchild
Jan 27, 2026 06:10 AM
foto1
Dec 15, 2014 10:58 AM
jscottleoanrd
May 25, 2009 08:49 AM
happikid
Oct 25, 2007 09:24 AM
solana
Aug 24, 2007 11:19 PM
