rough idle e320
Old 01-29-2005, 11:22 PM
sleepwalker's Avatar
Default RE: rough idle e320
[sm=interesting.gif]
  #32
Old 02-05-2005, 05:03 PM
Hi A Dalton
I checked the sticker under the hood, and there is nothing that says California version for the emission, on the connector with 8 input, I do not see any LED, just the 8 input holes and the little momentary switch next to it. so I am wondering how can I use the tool you described to get the fault code on my mercedes.
I also have another question, my 1988 300 SE will crank but not start, I checked all the sensors and relays, I replaced the coolant temp sensor, crankshaft position sensor (reference sensor) and still no start. Today I disconnected one of the fuel lines to an injector from the fuel distributor and crank the engine, no fuel was coming out, tried the same with another injector line and no fuel, then I disconnected the cold start injector line and while cranking there was alot of fuel squirting out of the cold start injector line. Can you please explain to me if this means that the fuel distributor is bad or if the plunger inside got stuck, or any other electrical component attached to the fuel distributir is faulty?
again thanks for your help.
  #33
Old 02-05-2005, 06:57 PM
Tool connections are
Blk -pin #1 or bat neg.
Red - Bat +
Odd color -pin #3
  #34
Old 02-11-2005, 12:21 PM
I connected the black to battery ground, red to battery +, and green to pin 3 on the 8 pin socket, pressed the momentary switch and nothing on the LED, does the momentary switch on the car has to be pressed also?
thanks
  #35
Old 02-11-2005, 12:45 PM
NO
If you have battery power to red and blk and NO led when pressing your momemtary switch, then you have not constructed the tool correctly.
You prob have the polarity of the LED backwards...
To test your tool, Just hook to battery [ +/- ] without using odd color and press the sw. Led should light
Next test is red to pos of battery and odd color to neg. .... led should light without using sw.
If neither of these work , you have made a construction mistake. Most likely, you have reversed the led leads .. they have to be in polarity .. or the led will not work. It is a light emitting DIODE and polarity sensitive.
  #36
Old 02-12-2005, 03:05 PM
Hi there
I think I didn't explain it correctly, when the black is connected to battery -ve, red is battery -ve, and press the momentary switch on your design (not on the car) the LED does come on, so the construction is correct, the part where the LED does not light is when I was trying to get the fault code from pin 3 at the 8 hole connector between the engine firewall.
any help is appreciated, and also on my question where no fuel was coming out of the port going to fuel injector while cranking while fuel does come out of the port going to cold start injector.
thanks again
  #37
Old 02-12-2005, 03:42 PM
OK
You do have to have the key in the RUN posistion.
If the led does not light when you press the sw with all conditions met, then your car does not have Flash code retrieve. [ Cal Mandate]
I am assuming your -ve on both battery connections is a TYPO in your previous post??
  #38
Old 02-13-2005, 04:00 PM
you are right, it was a typo
so in case the car is not a california version, then what is the use of the 8 hole connector? is it something to connect a special mercedes tool (Bosch) to read on/off ratio to get diagnostics?
thanks for your input.
  #39
Old 02-13-2005, 04:12 PM
Yes ,
It is ratio codes
The Cal version has LED Flash code access.
They all had flash after '89, and then went to OBD2 after 99
too_juicey
11-04-2008 08:39 AM
Frustration_X_2
02-19-2007 12:49 PM
jon98909090
01-20-2005 12:55 AM
jvision09
12-06-2004 12:05 AM
Quick Reply: rough idle e320
