REVERSE LIGHTS
Old Oct 31, 2007 | 06:20 PM
  #11
paulie's Avatar
Default RE: not charging
hi stuart, have'nt been on for a while. just wondering if you can help or ever heard of a problem that an E270 CDI altenator can give i.e no charge to the battery and the altenator is workin fine ?? just wondering if ya would have any ideas. battery brand new but no feed to small terminals.. dont know were the small feed comes from??
Old Nov 1, 2007 | 03:12 AM
  #12
snanceki's Avatar
"no charge to the battery and the altenator is workin fine"
I'm confused. This is CONTRADICTORY?
Not sure if the regulator is internal or external on your installation. Alternator output is controlled by a device (regulator) which moderates the field winding current. No field, No output.
Sorry can't be much more help. Sounds like your regulator is dead.
This is a common problem and can often be traced to an incorrect polarity jump start.
Stuart
Old Nov 1, 2007 | 07:06 AM
  #13
syedabdulshahid's Avatar
Default RE: REVERSE LIGHTS
Paulie,
Make sure that you put correct element (single/dual)
and correct wattage lamps.
Sometime this creates un-necessary problems.
Regards
Syed
Old Nov 1, 2007 | 09:37 AM
  #14
paulie's Avatar
thanks, but the reg is in the boot compartment,on the earth strap.the alternator is charging when the small wire goes live but only lasts a few mins then the blue small wire looses power and the alt stops output.my thinking is the reg is telling the alt to stop charging for some reason.reg is not available for a few days and is a bit pricy but have it ordered and fingers crossed.funny thing is it charges from cold but looses the small feed after a few mins.and has been going on for some time with lots of jump starts so this does sound like a reg prob.thanks again and ile let you know,all knowlage is worth passing on !
athenshome
Nov 15, 2010 02:19 PM
bugy
Mercedes A Class
Mar 14, 2008 12:16 PM
Tescoman
Jul 19, 2007 03:22 PM
Dehaven
Dec 23, 2006 05:09 PM
Andrew Maris
Apr 3, 2006 08:58 AM
