Replacing rear springs
Old Jan 14, 2007 | 01:45 AM
paulie's Avatar
Default Replacing rear springs
Hi, I need to replace the rear springs on my 98 E280/210 saloon and i was thinking about doing the job myself. I was wondering if there is anything i need to know before i do this. If any of you have done this job to your merc, how difficult was it. Thanks Paulie.
Old Jan 14, 2007 | 02:07 AM
MBZTech's Avatar
Default RE: Replacing rear springs
Piece of cake as long as you have a spring compressor..... Why are you replacing only the rear springs?
Old Jan 14, 2007 | 02:13 AM
paulie's Avatar
hi mbz, thanks for the reply. ive just changed the front springs and wishbones and the car is sitting up alot higher on the front so i was told to replace the rear springs to balance the car. if you compress the spring does that mean you dont have to touch anything else?
Old Jan 14, 2007 | 03:16 PM
MBZTech's Avatar
You can also buy different thickness spring pads to fine tune the hieght.....Now you have me second guessing myself. I think if you compress the spring far enough it will just pull right out....If there isnt enough room then you have to remove one of the lower control arm bolts and swing the control arm out of the way to drop out the spring.....Damn i cant rememeber now... Its been awhile since i changed rear springs..
Old Feb 23, 2007 | 01:41 AM
paulie's Avatar
Default RE: Instrument Cluster
hi i was just wondering if you new anything about repairing the Instrument Cluster on a 01 320cdi. i.e the loss of some of the pixel or digits on the clock and the outside temp. Is it possible to repair yourself????
Old Feb 24, 2007 | 02:15 PM
raymond~'s Avatar
ORIGINAL: MBZTech
exactly as you've described. dropping the LCA is the easy part. raising it while keeping
an eye/hand on the spring, the LCA bolt holes, and manipulating everything requires care.
very simple - just don't rush. the lower control arm technique adds another 30-60 mins
depending on type of spring you're installing, your tools and your technique. i found the
Klann type (pancake) spring compressor to be key vs the more traditional hook type
compressor.
use the Force...not force, and you'll be just fine.
quantass
Aug 16, 2009 11:54 PM
woof132
Apr 6, 2009 10:15 PM
boman49
May 8, 2007 02:28 AM
DGW203
Jul 6, 2006 12:07 AM
