Power steering noise problems
Does anyone know the location of the power steering fluid? I have a 99 E430 and seems like everytime I turn the steering it is making vibrating and grinding noise. Also it seems harder than it was. I read the forums on here. Someone had the similar issue and turned out to be the power steering fuid was low. Does any one know the location of the fuid ? And what type it takes? Thank you all!
RE: Power steering noise problems
Sorry for the late answer. I have only one day in this forum.
I will copy and paste the info that I found on another forum because I have the same doubt and I found the right answer.
"On my 1994 E420, it's to the right of the oil filter dipstick if you are standing in front of the engine, it has a black cap that you have to screw off. It's behind the right auxilliary fan on the side where the ABS motor is if you are standing on the front of the engine."
Gus.
Gus.
AMGMercedes
04-02-2007 10:49 PM
