Pollen filter 97 E320
Old Jan 1, 2004 | 05:21 AM
Paul's Avatar
Default Pollen filter 97 E320
Anybody know where the pollen filter and activated charcoal filters are located? I've owned the car for 3 yrs and figure it is time to replace them but haven't found them.
Old Jan 10, 2004 | 05:16 PM
egghead1's Avatar
<img border="0" src=smileys/smiley1.gif border="0"> Paul and anyone elese. My 1998 Wagon I found was a 30 min job including ordering the parts online. I saved 350 bucks.
remove the glovebox with a total of 4 screws. The the particle filters are behind a small cover right behind the glove box. Depress the keeper on the white clip and remove then the black cover. repalce the filters and reverse. The charcoals are inserted and removed from below the airbox. Below the dash on the pasenger side is a black panel. remove the two screws that hold it. Prior to removal remove the heater flor vent on the left side of the hump. Should pull away without damage. You will see to the left side two hard plastic keepers to covers for independant slots for the canisters. They slip in from the bottom up so remove your floor mat for clearance. Watch how this all comes out and put them in the same way. I have a good source for the filters if you need it. Good Luck
Old Jan 18, 2004 | 03:19 AM
bb964's Avatar
Can you please post the source for the <SPAN class=highlight>filter</SPAN>s.</P>
Thanks, Bill</P>
</P>
Old Jan 19, 2004 | 12:06 PM
egghead1's Avatar
I got a good set from THEPARTSBIN.COM
Old Jan 19, 2004 | 11:37 PM
bb964's Avatar
Thanks!!
Old Jan 20, 2004 | 03:07 AM
Paul's Avatar
Thanks, I found them!
ivanne
May 17, 2009 05:54 AM
dablk1
Mar 30, 2009 04:10 PM
parasuco
Mar 13, 2009 02:21 PM
Boulder GT3
May 27, 2007 01:22 PM
Lhaitzss
Mar 5, 2007 10:44 PM
