Po410 code
Old Apr 21, 2013 | 07:44 PM
Carlos3467's Avatar
Thumbs down Po410 code
I'm new to benz world just purchased 99 e430 sport in October check lite came on saying for 410 code have to do emission now I read something bout taking heads off drilling some ports really?......?. Who makes such a mistake
Old May 20, 2013 | 04:28 PM
PelicanParts.com's Avatar
Default Answer
Frequently the problem is a failing diverter valve.
Valve, shut-off valve LEFT MB# 0021403560
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Valve, shut-off valve RIGHT MB# 0021403660
Often by the time you get the P0410 code, the cylinder head air passage is plugged with carbon.
As preventive maintenance I suggest replacing both diverter valves and vacuum hoses.
Here is a trick I use:
* Buy a gallon can of PB Blaster. Note: some people prefer Trizol TM Technologies - Aero Braze - Flux Core Brazing Rod
* Let the engine cool
* Remove both diverter valves, being careful not to break the round end of the valve.
* Locate the port (hole) under the left/right diverter valve, and pour in 2 oz of PB Blaster in each hole.
* If the air passage is plugged, it will only hold 2 oz.
* Repeat the process every 12 hours for up to a week.
* Install the diverter valves, start the car outside because it is going to seriously SMOKE until the oil burns off.
* Drive the car for 20 miles.
** Repeat the process as needed, until the air passages open.
** Usually the air passages clear after 1-4 procedures.
*** After the air passages open; Pour in 2-3 oz of Berryman B-12 Chemtool Berryman Products in each port (hole) under the left/right diverter valve.
*** Wait 3-4 hours and drive the car (above 45 MPH) for 30 minutes.
whunter@pelicanparts.com
marshman 442
Dec 30, 2007 12:35 PM
travelman28
Nov 1, 2007 02:57 PM
mikedee
Jul 8, 2006 09:26 PM
mbenz66
Apr 8, 2006 10:25 PM
mbenz66
Mar 18, 2006 11:41 PM
