P2016
RE: P2016
Hi
P2016 = Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 1).
Where did you get your definition from?
Your definition means that the system is unable to achieve the required mixture since the injection duration is greater or less than the set range limits.
Give us a bit more info and maybe we can help a little more.
Stuart
Stuart
RE: P2016
Thanks for the quick response,
When the check engine light appeared, I purchased a diagnostics tool that I plugged to the car & it gave me code 2016 & 2085 (according to the code sheet that what it means)
I appreciate any information you can give
Thank you Thank you
Thank you Thank you
