Need help please! 2003 E500 starting problem
#13
I was going to suggest cps,but you did not mention the code and if they start to go bad no code,if they fail code.
www.autohausaz.com cheaper then the dealer
56 bucks free shipping
http://www.autohausaz.com/search/pro...ition%20Sensor
mercedesshop.com diy section diy.
located at about the 1 oclock position looking from the front of the car on the top of the bellhousing area just behind the engine.Pop the hood up all the way with the hood button located on the hood hinge and use a good flashlight to see down there.
more diys for it on benzworld.org w210 section in the diy area at the top of the forum.
ohlord
index the cps properly when you finish installing it.
ohlord
#14
we got it for seventy shipped to our house the bosch one as well from a local euro shop... ive read all the diy things.. but I still cant seem to find... I will try again right now.
#15
I wish the check engine light would come on in my car...it won't...something is obviously teeing the computer off to the point where the engine acts goofy but will not trip the check engine.....that would be great....I swear the O2 sensor is shot but 90% of the time the car starts and runs great...it's the other 10% that leaves me with trepidation...and that's the most important 10%...plus I noticed in the rain today after driving the car that there was one of those little rainbow looking rings (as when petroleum mixes with water) right underneath the tail pipe...tells me engine running rich, unburned fuel coming out the exhaust...good luck on this issue
#16
okay I found it once I got the engine cover off... I used to think you werent allowed to take it off... but now to find that torx socket... hopefully we have one laying around... there isnt any part stores around.
#19
Don't ever jump the starter posts on a mb with das.The starting cycle needs to be generated by a rolling code supplied to the das system.You can royally screw up your ability to start the car.His code is cps,clear failure when it comes up,replace it and problem solved.
ohlord
ohlord
MARIODRIVE
11-23-2008 05:39 PM
