Need help locating starter motor 94 e320
Old Oct 22, 2008 | 10:06 AM
izim93's Avatar
Default Need help locating starter motor 94 e320
Hi guys,
I need help locating my starter motor for my 94 e320. I have a no crank issue. I've done most tests, Nss, checked and spun fuses, ignition switch checked out, even the x-27 bypass test and the problem seems to be downstream. I want to test my starter next. I have the Alldata info, however that particular drawing isn't giving me enough info to recognize where it's located.
I need a real photo of one installed or a location reference, say from the alternator.
Big thanks in advance for all your help.
94 e320 124.032
Old Oct 22, 2008 | 08:10 PM
cliff's Avatar
Default RE: Need help locating starter motor 94 e320
although I am not positive about your model, typically follow a wire off the positive post off the battery and you should locate the starter motor eventually. I have never seen a starter yet that wasn't directly attached to the battery somehow....good luck
Old Oct 23, 2008 | 04:20 PM
izim93's Avatar
Thanks for your help Cliff.
I feel I'm probably looking over it, but I'm still unable to trace it down. So
if anyone else would like to chime in on this one, your help would be greatly
appreciated. MB 94 e320 (124.032) 104.992
Old Oct 23, 2008 | 06:13 PM
ohlord's Avatar
Banned
Look at the engine head on,follow the right side back along the block along the center line of the engine to the point where the engine meets the bell housing for the transmission the starter sticks out towards you from the flywheel direction towards the front of the car.You will see it big as day.
ohlord
Old Oct 23, 2008 | 07:03 PM
izim93's Avatar
Thanks ohLord. Needed that type direction.
Big thanks to Cliff and Ohlord for the assist.
michaels3d
Dec 18, 2011 10:47 AM
tobence
Aug 17, 2009 05:10 PM
justaride
Dec 8, 2007 12:59 PM
z06bigbird
May 16, 2007 12:45 PM
IluvS500
Oct 26, 2005 01:50 AM
