Need help to fix AC in my 99 E320
Old Jun 3, 2012 | 07:19 PM
zdzich's Avatar
Default Need help to fix AC in my 99 E320
Found no leaks. The AC compressor turns on for about 15 seconds and then goes off. Checked the pressure in the system with engine running and climate control turned on for the lowest temp. Low side has about 100 psi and the high side about the same. Any ideas ? I will appreciate your feedback.
Old Jun 3, 2012 | 08:16 PM
chassis221's Avatar
low charge or too high charge. make surre you have the correct amount in there. most likely the problem is the wrong amount in the system
Old Apr 6, 2013 | 02:16 PM
buck777's Avatar
chasis i appreciate your knowdledge on these cars i saw this post and another one you posted about a small freon line from dryer to evaporator,,that had a tendency to leak a lot i checked it today for the first time and bingo,,that was where my leak was,,,i appreciate you ,,,thanks buck
Old Apr 6, 2013 | 07:50 PM
chassis221's Avatar
You are welcome! Glad I was able to help you.
Old Apr 20, 2013 | 04:38 PM
buck777's Avatar
just got through doing my e320 sedan 2001 ,,,,it must have 2.2 lbs for a full charge,,it wont even start cooling till at least 1.6 lbs,,,had to reset the control module to get eco light to go off and compressor to stay on,,which worked by the way i wrote down the procedure
abcdetech
Mar 18, 2008 08:44 AM
islandercreation
Dec 4, 2007 11:31 AM
andruxa69
Oct 3, 2007 04:23 PM
forearms
Sep 3, 2007 01:44 PM
gabriellaavet
Apr 26, 2007 04:56 PM
