Need Help E320 electric problem
Old 01-09-2011 | 01:41 PM
kevine320-2000's Avatar
Default Need Help E320 electric problem
Driver side window - mirror and seat controls don't work (front driver side)
some times they come back on for a short time
all other windows work fine at all times
passanger side mirror works fine
cigerette lighter in front is also out???
any idea where to look for ground short or something?
fuses seem to be ok ? I think
Old 01-10-2011 | 07:57 AM
Default driver window switch not working??? help
front driverside window seat outside mirror all do not work??
all other windows and passanger side seat and out side mirror are fine!
heated seats work fine both sides.
any clue? shorted ground wire read some where wires going to drivers door may be frayed but they look ok can not see them that well with the boot in the way
Old 01-10-2011 | 05:08 PM
chassis221's Avatar
try unplugging the passenger side rear window motor...remove the door panel, and the plug is easily accesable. sounds rediculous but ive seen it before. if that fixes the problem then youll need a new window motor.
m1943
08-02-2010 12:17 PM
piglit91
06-21-2009 04:51 AM
gslama
06-27-2007 09:58 AM
grid
09-26-2006 12:43 PM
boman49
04-16-2005 02:29 AM
Quick Reply: Need Help E320 electric problem
