My trunk won't close
Old Sep 25, 2008 | 03:58 PM
300EBenzDriver's Avatar
Default My trunk won't close
My 1990 Mercedes 300 E trunk won't close. The trunk has always been difficult to close- in the past I had to slam it down with much force. The latch appears to be fine. The top metal piece isn't bent or distorted, but the plastic around it slightly damaged- it almost looks as if it has been chewed on. However, I don't see how it would prevent the trunk from closing. The bottom spring mechnisim reacts appropriately. A bungee cord will do for now, but please help! Any suggestions?
Old Sep 26, 2008 | 02:01 AM
ohlord's Avatar
Banned
Default RE: My trunk won't close
The chewed up look is because the latch is out of alignment.You need to adjust it or have it adjusted by a body shop that does MB.
ohlord
you should be able to tackle the job yourself.
Old Oct 8, 2008 | 01:03 PM
dscabicky207's Avatar
Agree. My 95 320 cab has the same problem. Loosen the bolts on the top part of the latch and fiddle around with their allignment to bottom part
miishmiish
Jul 26, 2022 05:31 PM
Wiz
Apr 8, 2009 12:44 PM
dgrover
Sep 3, 2008 08:47 AM
darrylsc
Jun 18, 2008 12:23 AM
chueman
Feb 15, 2008 04:37 PM
