My trunk won't close
My 1990 Mercedes 300 E trunk won't close. The trunk has always been difficult to close- in the past I had to slam it down with much force. The latch appears to be fine. The top metal piece isn't bent or distorted, but the plastic around it slightly damaged- it almost looks as if it has been chewed on. However, I don't see how it would prevent the trunk from closing. The bottom spring mechnisim reacts appropriately. A bungee cord will do for now, but please help! Any suggestions?
RE: My trunk won't close
The chewed up look is because the latch is out of alignment.You need to adjust it or have it adjusted by a body shop that does MB.
ohlord you should be able to tackle the job yourself. |
Agree. My 95 320 cab has the same problem. Loosen the bolts on the top part of the latch and fiddle around with their allignment to bottom part
