lowering plug-and-play device
Old Feb 16, 2019 | 10:03 AM
AlfaPacino's Avatar
Default lowering plug-and-play device
hey guys!
I'm researching a lowering module for the 213, I cam across the loweredbenz which is a 1/3 of the cost of Renntech and achieves the same goal with the exception that you set it and forget it instead of being able to adjust it using android device.
Do you have any experience with the OBD and what are your thoughts?
Thanks a lot!
Old Feb 16, 2019 | 01:41 PM
DGebber's Avatar
Hey
I have one on my S63 W222. It works just as promised. I use it in custom mode. You can adjust it down to -70mm and the car will be slammed. But I wouldn’t recommend driving it that low, because you will 100% cause negative camber wear on the tires.
MDN
Jan 23, 2008 06:42 PM
