Locked boot and disconnected batter
Locked boot and disconnected battery
Hi everyone,
I have a Mercedes E220 (w211) built year 2005.
I was replacing the rear passanger side seatbelt and for that I disconnected the battery. Without noticing, I closed the boot and when I tried to open it, it will not open.
Neither manually with key nor with remote control I can get it open.
Can somebody suggest a way to open it? The battery is still disconnected. There is no current in car.
Cheers.
Cheers.
the blade key should work,,,usually insert the key turn it then push in.( actually i dont think your button pushes in on the tumbler.) since you have a pull handle to open the trunk. trunk should open. try turniing the key both directions. does the blade work in the front door?
bboyer32
11-20-2009 12:41 PM
