Location of Crankshaft Position Sensor and Fuel Pump Relay-01 E320
Old Mar 29, 2007 | 06:16 PM
BenzoDJ's Avatar
Default Location of Crankshaft Position Sensor and Fuel Pump Relay-01 E320
Where is the Cranshaft Position Sensor and Fuel Pump Relay Switch located on an 01 E320. I think the Sensor is located on the rear of the engine. If so, do I gain access to the Sensor from the engine compartment or from under the car? Where is the Fuel Pump Relay Switch located? Your insight will be appreciated.
Old Mar 30, 2007 | 03:37 AM
snanceki's Avatar
Default RE: Location of Crankshaft Position Sensor and Fuel Pump Relay-01 E320
CPS. At the back of the engine on the bell housing towards the top. Not sure on E class but would expect this to be from under the bonnet.
Easy replace job.
Old Mar 30, 2007 | 02:34 PM
Neon's Avatar
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=203061&M=112%2E912& GA=722%2E696&GM=716%2E623716%2E634&CT=M&am p;cat=19X&SID=15&SGR=075&SGN=04
As borrowed from the C-class forum. This is the picture of the M112 CPS location.
The fuel pump relay is in the fuse box on the driver's side. Look for part no. 002 542 13 19
Old Mar 30, 2007 | 08:01 PM
BenzoDJ's Avatar
Thanks guys for the information. Very helpful.
orlitex
Dec 30, 2015 12:07 PM
lucky chucky 1
Jul 9, 2015 02:17 AM
naseeb
Oct 24, 2011 08:22 AM
kupiec79
Oct 28, 2009 09:26 PM
CCCP
Feb 25, 2005 10:41 AM
