left turn signal stuck
does anybody here experienced their turn signal stuck? my LEFT TURN SIGNAL is stuck whether its on/off position.[:@] my right turn signal works okay.
any advise is much appreciated. thanks
car info:
2001 E200 Kompressor
VIN: WDB2100482B38817
ENGINE: 11195732230619
car info:
If you have an aftermarket / non-mercedes car alarm fitted. And this alarm flashes your indicators. This can be the problem. The relay contacts in the alarm unit tend to weld together leaving one or both indicators constantly lit. As a quick test, disconnect the multiplug from the alarm and see if the light goes off. If the alarm manufacturers would use a relay capable of handling the current involved in flashing front and rear and side repeater bulbs all at once ( up to 5 amps in some cases ) we wouldn't have this problem.
Hope this helps.
Brian.
Hope this helps.
Brian.
