Lamp Defective light???
Old May 4, 2004 | 10:01 AM
mbmiller's Avatar
Default Lamp Defective light???
I just received a "Lamp Defective" signal on my dash. It appears that my headlights and parking lights still work fine, so does anyone know what this indication light might mean?
Thanks,
Mbmiller
97 E320 77K miles
Old May 4, 2004 | 01:37 PM
sebastianforbes's Avatar
Default RE: Lamp Detection???
hi there
to quote from the book ---
at key position 2 in steering lock the indicater lamp weakly lights up and should go out with the engine running.
flashing of indicater lamp at key position 2 in steering lock or with the engine running indicates the failure of a bulb.
if a bulb of the vehicle exterior lighting is burnt out, the indicater lamp only lights up as long as the exterior vehicle lighting is switched on.
if a bulb of the stop lamps or the turn signal lamps is burnt out, the indicater lamp lights up when braking or actuating the turn signal and goes out only after the engine is shut off.
notes.
the indicater lamp also lights up when a wrong type bulb is installed.
cheers
sebastian.
Old May 5, 2004 | 12:02 AM
mbmiller's Avatar
Sebastian,
Thanks, I discovered that it was my brakes lights. More money into the car, again.
Mbmiller
7laker
Jul 8, 2009 12:52 AM
greenfoot
Dec 22, 2008 10:53 AM
Barb B.
Jan 23, 2008 08:28 PM
davey_fl
Sep 24, 2006 04:36 AM
Sphil98clk320
Jul 3, 2005 01:23 PM
