key battery replacement message not going away
Old Feb 6, 2016 | 12:12 PM
Rick Coup's Avatar
Default key battery replacement message not going away
My 2014 E350 prompted me to replace the key battery. I did it. But it still asks me to replace it. I changed to another new battery, it keeps saying to replace it. Any thought?
Old Feb 15, 2016 | 11:30 AM
chassis221's Avatar
make sure your usuing the correct battery. CR2025 I think it is
Old Jan 20, 2022 | 09:12 PM
Marsbro07's Avatar
Old Feb 15, 2022 | 04:41 PM
mlonas's Avatar
My 2012 E350 was doing the same thing. The dealer suggested that it was the off-brand Amazon batteries that I was using. I took it in for the airbag recall and they looked for a cause of the key issue. They found one stored fault for a "keyless go antenna" but found the system is operating properly. They put in a fresh "Mercedes recommended" battery and we haven't had any problem since then (11 Feb). I don't know if the battery was the issue or if they corrected some software issue during their diagnostics.
I would make sure you put a fresh, high quality battery in the key and see if that improves the situation.
Good luck!
Edit: The fresh battery did not solve the problem. I am chasing another electrical problem with the driver side headlight and the two may be related...
nopcbs
Dec 31, 2012 05:43 AM
nfpacct
Apr 30, 2011 05:50 PM
Avg_Joe
Apr 12, 2011 03:23 AM
ponceco
May 23, 2007 05:27 PM
AAmais88
Jul 26, 2005 01:09 AM
