interior light
interior light
1994 e320 wagon The interior light does not come on when the door is openned. The manuel switch works from the light - but not the auot part.??? I wonder if the entire light assembly comes out and the switch is bad or??????
Lee
Lee
RE: interior light
the overhead interior lamp receives ground signal from the door switches. expose it and check if you get any ground signal by actuating each door switches. if you do, then have that unit repair or replaced.
you have no problem with power supply because it works manually, so fuse and wiring is ok.
lentomies
10-30-2012 12:33 PM
Kikoap
07-30-2012 02:50 PM
Kikoap
03-27-2012 10:37 PM
