idle adjustment te300
Old Aug 9, 2008 | 03:38 PM
amhjab's Avatar
Default idle adjustment te300
how do you adjust idle in a 91 300te inline 6
Old Aug 17, 2008 | 11:36 PM
nescid's Avatar
Default RE: idle adjustment te300
Normally, you have the idle control valve that should take care of that communicating to the ECU/Computer Brain, and to the MAS (Mass Air Sensor). They communicate together sending thousands of pulses/signals depending on engine load to maintain a smooth engine running. However, overtime, the Idle Control Valve could become faulty resulting in erratic too high or too low idling. There are associated components which could be at fault but mainly it could be the Idle Control Valve. One possible easy to replace thing is the Overload Protection Relay located close to the battery. Upon proper diagnosis, I could probably help you with used parts since these are very expensive when new.
Old Aug 18, 2008 | 07:09 PM
cliff's Avatar
you can't adjust the idle...can't do it
TCBC01
Dec 17, 2010 05:49 PM
lcs164
Jan 23, 2007 11:27 PM
chicomerc
Dec 10, 2006 08:43 PM
ggenovez
Jul 11, 2005 01:11 PM
Guitar Factory
Dec 26, 2004 12:52 AM
