How do I disable the speed senstive radio volume control
RE: How do I disable the speed senstive radio volume control
Standard MB radio?
Not sure about this reply because radios are different market to market.
However if there is a AVC Automatic Volume Control which is linked to road speed on your radio then this feature is USUALLY customer configurable.
I would expect it to be a function with access gained thru the Tone/Fader/Balance/Programme Preference type menus. Usually appears as +X or -X with + causing the volume to be greater at speed than when - selected just like on the Tone control.
Hope this helps a little.
Stuart
Standard MB radio?
Stuart
Yes it is a standard MB radio. I think made by Bose, at least the speakers are. I looked at the controls on the radio itself and other than bass, treble, balance, and fade their is no adjustment that I see can by made under the AUD button. On the dash, you can change the radio stations. Next to the radio station up top to the right it does say SP. Does this have anything to do with thevolume control on the radio. Idon't know how or if this can be changed. Any ideas?
Bose will be just for the speakers.
Sounds like your set has real ***** for Tone etc rather than software/menus.
Sorry out of ideas without make/model etc. but someone else may be able to follow up on standard MB.
Stuart.
Stuart.
