How to change oil for 2006 E350 ??
follow the diy oil and filter change#2 resource section on
www.mercedesshop.com
,pretty much the same for all m112 and m113 engines.
topsider or mityvac $45-$65 online
fleece filter from www.autohausaz.com
You fill the mobil1 0w40 syn and check level on your dash read out per your manual.
reset of service indicator light is in your owners manual.
ohlord
no looking for drain plugs the oil suctions out the top.
join the w211 section on mbworld.org and also on benzworld.org
ohlord
I know this is an old thread but...
How much work is it to drain the oil ? I have ramps and if it's just a matter of a few screws/clips then I will do that. Done this on a BMW and it was just a matter of a small panel that came off easily.
OTherwise I Will have to buy one of those suction devices.
