Help: 2010 E550 Radiator Drain
Old Jun 7, 2017 | 08:42 PM
GMBE550's Avatar
Default Help: 2010 E550 Radiator Drain
I want to drain some coolant so I can replace the thermostat. Jacked and stands under the front jack points. Removed the covers underneath and opened up up the collant tank cap. Drain plug is not like the manual, its on the side, recessed, and has a yellow stripe across it. I turned it 90 degrees ccw, and nothing. stuck a pin punch up the drain hole, I can feel it hit the plug but again, nothing. The drain hole has no old dirt or gunk in it.
Am I missing something here? when I turn the plug 90 degrees ccw, it feels like it hits a stop. I don't want to force it. What to try next?
Thanks in advance
Manowits
Jul 29, 2010 05:51 PM
moosehead
Jun 14, 2010 05:41 PM
trev0006
Jun 10, 2009 08:54 PM
trev0006
May 14, 2009 03:00 AM
