headlights
Old May 26, 2007 | 02:26 AM
shoot the j's Avatar
Default headlights
how hard is it to change out headlights on a 2001 mercedes e320?
Old May 26, 2007 | 03:52 PM
chassis221's Avatar
Default RE: headlights
you have to remove the front bumper not totally but remove it partially frontward then you can pull the light out. there are screws for the headlights on the side of the bumper behind the bumper side marker. so you need to remove bumper out of the way for access to screws.
Old May 26, 2007 | 08:48 PM
FourMatic's Avatar
do you mean replace the whole headlight assembly to give it the 2003+ look (HID)? or do you just mean the bulb inside the headlight housing?
Old May 28, 2007 | 08:31 AM
K1MOTORSPORT's Avatar
Check our vendor page for 2003+ look headlamps and HID kits.
Old May 30, 2007 | 03:19 PM
well i was shooting for a 2003 e320 look. or hid swap as well. my wife drives the car and wants to change the headlights because they are too oxidized even for me to clear up. its from the inside. the previous owner had the car in nevada in the sun all the time. any suggestions? projectors? hid?
Old May 30, 2007 | 03:42 PM
2003 style projector headlamps
HID kit
Old Jun 5, 2007 | 11:07 AM
whats your contact info and how much would those lights and hid kit run? i live in san diego, ca
Old Jun 5, 2007 | 12:03 PM
The headlamps are $369.99. HID kit is $249.99. Slim HID kit is $299.99. You can contact us via email (sales@k1motorsport.com).
ORIGINAL: shoot the j
Old Jun 8, 2007 | 05:29 PM
  #9
FourMatic's Avatar
K1:
I just got my headlight unit from the FedEx guy the other day. I'm in a 2000 E430 with OEM H7 heiadlights. Do I just use those headlights? or do I have to buy the D2S bulb and change the fuse too? Because if I do get the D2S lights, don't i need a new ballast and HID kit?
I bought "DEPO Clear Projector Headlamps for 00-02 E-Class
Convert your E-Class to 2003+ look. Easy plug & play. No modification is needed" from you.
Thanks,.
Old Jun 8, 2007 | 05:34 PM
  #10
Install is direct replacement.
If you want HID, then you need HID kit with H7 HID bulbs.
ORIGINAL: FourMatic
K1:
Thanks,.
