fuel filter loacation and cooling flush
hi,
Where is the fuel filter located in a 1997 mercedes benz e320?
Also is there a drain on the engine block to drain the coolant from it? If so where?
Thanks for replies in this post and in my other posts?
Nick
Nick
Bottom of car, driver side, under your rear passenger seat. Easy replacement, just remove the plastic cover. Unclamp carefully because fuel probably is under pressure. Can't help you w/the coolant drain.
