E220 CDI decelaration surging
Old Aug 19, 2012 | 07:22 AM
SoxmisUK's Avatar
Default E220 CDI decelaration surging
Hi total noob to Mercedes here, please be patient.. Just got the car, in nice condition, however when out driving I have noticed that when decelerating the engine "Surges.." as if I am tapping, or blipping the accelerator and the car surges a little with each "Blip.." .. Every two or three seconds..? - Happens all the time.. Thought I could live with it, but now I feel ready to pull some spiders legs off.
Can anyone help me on this problem? (Not the spiders legs thing, but the car..)
BTW this is our first mercedes ever, and I must say we love it, dont know why we didnt get one years ago, what a unique ride they are. If I wasn't an enthusiast before, well, I'm going to be one soon...! Opening the bonnet of this was a little daunting as there's nothing I can say I recognise straight - off, apart from blindingly obvious things like oil and washer reservoirs..are there any resources for workshop guides etc. anywhere online?
R'gds..
John.
Old Aug 23, 2012 | 12:20 PM
PelicanParts.com's Avatar
Default Answer
With your symptoms.
Have the Mercedes dealer inspect the intake manifold air flaps, they are a constant common weak point on the CDI.
roy@pelicanparts.com
Old Aug 23, 2012 | 05:47 PM
SoxmisUK's Avatar
I've meanwhile enlisted a friend of my brother's to look at it he's a diesel mechanic. (Actually runs a diesel specialists shop..) He'll be on holidays for another 10 days, but he's a reliable guy.
He's already formed a (Telephone..) theory of a leaking vacuum pipe/seal which I half suspected, but he needs to hear and diagnose it for himself...
But he will be interested in this Intake Flap idea too. Which could turn out to be not too expensive to repair either.. Hmm.
Are they metal those manifold flaps? or some nylon/plastic? I must say I've never heard of them breaking through either wear or abuse in many, if in any other engines at all.
B'rgds..
John.
Originally Posted by PelicanParts.com
With your symptoms.
Old Aug 24, 2012 | 05:22 AM
coolishlobster's Avatar
the intake plastic flaps are a big problem on the cdi....its used for engine breaking and smooth air intake using the swirl method....changing the manifold is a fairly big job but i would try using a diesel air intake spray from the egr side and this will help loosen and clean the carbon deposits that cause the flaps to stick and cause the problem.....also its controlled by a electric servo motor mounted under the manifold that go bad and is connected to the flaps by linkages you can look deep under and see if these are all working as you rev the engine up,its like a rail with links to each flap and these can break away....they should all work together and if not you have found a problem that could also cause you problem you described......hope this helps.
Old Aug 24, 2012 | 09:26 AM
SoxmisUK's Avatar
Thanks for that extra info Coolish, I'll have to wait until the guy comes off holiday to get a proper diagnoses, but this is all great information that we'll be checking out when the guy starts work. I promise to post back the findings/results as soon as I get some.
I have noticed that fuel economy is a little poor at the moment, around 28 UKM to the gallon, and I'm hoping fixing this problem may well help there.
Old Aug 25, 2012 | 03:43 AM
no worries good luck. .Regarding mpg if these flaps are not working correct it would have a big impact on using more fuel.
NigeAus
Feb 9, 2013 09:54 AM
d4vey
Dec 21, 2005 07:42 AM
d4vey
Dec 15, 2005 05:58 AM
sicce
Sep 17, 2004 11:04 AM
Gatsu986
Aug 27, 2004 12:24 PM
