e 320 1995 coupe where is central locking pump pls
Its suppose to be in your rear bonnet open up the rear cover either on the right side or the left. to identify it well its connected with plastic hoses on it coverd inside a sort of buffe sponge thing
but im sure it be coloured in yellow but bare this in mind before you dismantle it. Take a picture so you can remember which hose goes to its original location
Good luck!
Good luck!
hi ,i found mycentral lock pump .thank you rockafella174 mine was under the passager seat,but you put me in the right area. now i need to remove my switches cluster centre dash.on the c class its easy ,but the e class coupe,1995 ,i cant see any screws but it very tight,seems i might break it as i lever it out any ideas anybody please,pete
