Do I need rear wheel bearing?
Old May 10, 2008 | 01:06 PM
ZEN3601's Avatar
Default Do I need rear wheel bearing?
I have a '94 E320 Cabriolet with 49,000 miles. My independant shop thinks I need a passenger side rear wheel bearing because of a noise they hear. I jacked it up and could detect no play at all in the wheel. The wheel does make a noise, but I think it could be tire noise. Is there a definitive test for a bad rear wheel bearing?
Thanks...
Old May 10, 2008 | 02:52 PM
ohlord's Avatar
Banned
Default RE: Do I need rear wheel bearing?
Raise the wheel and spin it as fast as you can by hand.If you can hear the noise then you know it is not tire on road noise and you need to do the bearings.
ohlord
alldatadiy.com has the diy also
http://www.mercedesshop.com/Wikka/W124RearWheelBearing
Old May 12, 2008 | 07:30 PM
ZEN3601's Avatar
I spin the wheel (I tried both sides) and the only sound I get is a little friction from the brakes. No rumble or grind from the bearings.
mick.anic
Apr 17, 2013 12:30 PM
914six
Sep 18, 2006 05:45 PM
lostinatl
Apr 24, 2006 09:44 PM
12magnum
Nov 9, 2005 03:30 PM
BILLS300TD
Oct 12, 2005 03:40 AM
